Howdy
If you are only missing TAIL LIGHTS then the problem is most likely in the wiring from the cab back to the light housing. Many times there is a "splice-job" with scotch-locks by the rear end for trailer hook-ups and that can cause all kinds of problems.
If you are missing all normal driving lights: front markers, tail lights, cab markers ect... then I would look at the switch itself in the cab. These switches were prone to overheating because the factory ran full current through the switch. If you pull the switch out it should be obvious if it damaged.
That's how I would start....
Hope this helps
2001 Chinook RV, V10 gas
1967 GTO, 1989 Honda Transalp
3 kids, 1 wife, 1 dog
