Thread: Built transmission issues
    Jul 2016
    USA north carolina
    Default Built transmission issues
    Hey guys got a transmission issue. It's got carbon fiber clutches shift kit... Blah blah but it does not slip runs great till it hits 190 degrees! Then it hits limp mode at 190 degrees only when it down shifts from 4th to third. It never hits third just kicks torque convertor out and stays in fourth all the way till it stops. Any info? Replace #1, 2, 3 solenoids and temperate senor. Stop for a bit but started up again.
    Welcome aboard!
    New clutches and they don't slip. Good. Now, your power will seek the next weakest link in the chain. Are you running a stock converter? If so, that may be what it found. Pull the DTC's and have a look at the complaints. Over-boost can also cause the same issue and limp mode. The SES lamp should be on, or have been on at some point, in any case.
    Jul 2016
    USA north carolina
    Thanks yea it's about 3 years old now doesn't slip one bit floor it from a dead boosted launch all the way till she red lines even at 190 degrees or above until it shifts down. Triple disk billet converter. Codes I will look at soon can't remeber what it was last time something about solenoid f. Thanks for the response was hoping someone had this issue before.
