Hi Guys;
Been a while since I posted anything. That is because my truck has been running perfectly, until now.
Here is my problem. Yesterday I was driving my truck around town and had stopped at LOWES for some building material. When I started the truck I hear this terrible metal rattely noise. It would go away when I would increase RPMs above idle. I thought it was a bearing going on one of the assessories. So I drove it straight home about 3 miles. I opened the hood and looked around and noticed that he Fuel Injection Pump was vibrating quite noticeably. I immediately shut it down and started looking. I noticed that at least two of the Injection Pump monting flange nuts were missing. I couldn't see the third too obstructed but I believe it must be still there or I don't believe the truck would have still ran.
Sorry for the long story but, here is my question.
1. Can any of you guys tell me what size and type nut I need or part number?
2. Do you think that the Injection Pump was damaged? (The truck ran fine.)
3. What all should I check to ensure there is no damage to the IP.
Thanks for your time.
1997, C2500, excab, SB, 6.5TD (L56), 130,000 miles.<br />DSG Gear Set, Kennedy 3.5" Exhaust System, Killed the Cat.
