Unfortunately, it's not that uncommon. His frame is probably built by Lippert Components, who make most trailer frames for nearly all the towable RV manufacturers these days. Lippert has had a few issues over the years with the frame breaking around the pin box. There's probably not much that Keystone or Lippert will do on a 10-year old rig, but it might be worth a call to either one. I will get you the customer service numbers tomorrow, if I don't forget.
Otherwise, just plan on having someone drop the bulkhead (plastic/fiberglass covering on the bottom), and weld in some bracing on the pin box. It's not big of a job, other than usually the trailer is not near a welding shop when this needs to be addressed. Sometimes you can find a good, mobile welder in situations like this.
