Results 1 to 14 of 14
Thread: Need some input on pump options for my Used Engine Oil.
    May 2008
    Columbus GA.
    Kind of what I was thinking. I was wondering if a sewage pump would be different than just a water pump.
    1995 Ford F350 Crew Cab Dually with a 7.3 liter Powerstroke
    198? Chevy aircraft tugger with a 6.2 liter "Tugger"
    A sewage pump may be more robust to handle more than just plain water, but coming from Horrible Fright I somewhat doubt that they’re using more substantial materials for the seals.
    Diesel Page Member #2423
    May 2008
    Columbus GA.
    Agreed. Their pump got me thinking about using one.
    Apr 2004
    Ottawa, Ontario
    Quote Originally Posted by Lonesome7.3 View Post
    HF has a viton seal kit for their pressure water pumps (Less than $100). Used these pumps for my bio-diesel operation. Output volume may be too high for what you intend to use it for.
    How much oil will you be transferring at a time? I built a transmission/engine oil exchange system that used two 10 gal translucent HDPE tanks (so I could see the oil level) and hooked up a $150 HF vacuum pump @5 inches vacuum for sucking out the oil and my compressor @5PSI on the other to transfer the new stuff.
    If memory serves, total cost was less than $200 bucks and could do a tranny oil change in under 1/2 hour.
    Bill
    94 Cadillac Fleetwood (sold)
    08 Aerolight 23TT
    May 2008
    Columbus GA.
    Whenever I fill a 55 gallon drum I will pump it into my dirty tank. That might happen every couple of months. I am interested in your set up. Would you happen to have any photographs?
    Madison, AL
    WAM, 2500HD D/A ext cab 4X4, 1997 Suburban 6.5TD K-1500.
    May 2008
    Columbus GA.
    That is neat. But i think I would have it wore out quickly.
    Apr 2004
    Ottawa, Ontario
    Sorry no photos. Just duplicated the tranny oil exchange system they use in the quick lube joints except I used stronger tanks that could take a slight vacuum and low pressure.
    For your uses, check with your local propane distributor. They always have "stale dated" tanks of all sizes. The tanks are not necessarily bad, just beyond their useful life as pressure tanks.
    Remove the brass valve from the top and then fill the tank with water. This is for assurance it won't go bang when you start drilling into it. Would tend to ruin your whole day. A 100 lb tank should hold close to your 55 gallon drum of oil.
    In the bottom of your tank, drill out a hole sized to thread in a 3/4 inch NPT fitting that you will attach a ball valve to. Where you removed the valve from, you want to install a brass tee and two smaller ball valves. One will have an air fitting on it and the other will have a vacuum fitting (steal one from the AC system on your car).
    To drain your 55 gal drum, connect a hose to your bottom fitting and open the ball valve. Start your vacuum pump and connect it to the AC fitting on the top and open the valve. This puts you into suck mode and will drain your 55 gal drum surprisingly quickly. Let it suck some air in at the end to drain your hose then close off your bottom valve. Close your vacuum valve. To transfer the oil into your other tank just apply air pressure to the other top valve, insert your hose into the other tank and open both top and bottom valves.
    Again, less then $200 bucks including a HF vacuum pump and all the valves.
    Some safety considerations:
    1. Propane tanks are rated for 150 PSI working pressure so the burst pressure is about 3 times that, WHEN THEY ARE NEW. To be safe, keep it under 30 PSI.
    2. I have taken a propane tank down to 29 inches of vacuum (negative 1 atmosphere about minus 15 PSI) but that was on a new tank. Pressure vessels are just that, designed to handle positive pressure, not necessarily vacuum. A good example is your typical 55 gal drum. They have a burst pressure of around 40 PSI. Less then 10 inches of vacuum (negative 7 PSI) will crush them flat. To be safe, I would keep the vacuum below about 15 inches for your propane tank.
    You really don't need a lot of either pressure or vacuum to move liquid unless there is a significant height difference. Even then you would be surprised just how little of each is needed.
    Hope this helps
    Bill
    08 Aerolight 23TT
    May 2008
    Columbus GA.
    I was just at HF and found nothing that could help. It was a small store though. Maybe they have the stuff I need on line.
