Thread: 2005 c4500 LED 4x6" headlight conversion
    Feb 2017
    Sedro Woolley
    Default 2005 c4500 LED 4x6" headlight conversion
    Up grading to LED 4-4x6"-old high beam is 2 prong (hi & grnd)-new led 3 prong-tried led w/hi & grnd-doesn't work. DRL &low beam works but when switch to hi beam low goes out-old seambeams worked fine. Any ideas?
    Dec 2002
    Teton Valley, Idaho
    LED's are polarity sensitive. Hook 'em up backwards and they won't work.
    Simply, if the connectors don't match, you have the wrong kit. They can be made to work, but you shouldn't have to do that when it should be right the first time. LED's are polarity-sensitive, as the previous reply states. A correct (or higher quality) replacement wouldn't have this issue.
