Results 1 to 5 of 5
Thread: 6.5 Project goes bust
    Feb 2006
    Hollywood, CA
    Default 6.5 Project goes bust
    I'm not going to finish this project and it has to go.
    6.5, 599 block with heads, good oil pan, valve covers have some interior rust.
    Block is mounted on a heavy duty (1,200 lbs?) engine stand that goes with it.
    $50
    Here is a link to the rust condition of this engine:
    http://www.thedieselpageforums.com/t...ad.php?t=45252
    No shipping, located in Los Angeles. First come, first serve.
    Have more parts, will post when I can.
    '87 Blazer, 4x4, 6.2, 700R4, 4.10, Silverado Pkg and rusty. Drivable donor.
    '85 M1009. 350, TH400? Gears probably 3.08? A few dings but that's what Camo paint is for right? Currently unlicensed and being taken apart.
    Feb 2006
    Hollywood, CA
    Still have it. Price lowered to $25
    I wish I lived closer... If the block decks have not been planed and the cylinders not bored, it is likely salvageable.
    I need a crankshaft - really need a crankshaft, but shipping is a killer. So, save the crank if there is no rust and no scoring on the journals (or sealing surface on the rear of the crank).
    If you decide to remove the crank, please ask for advice on how to do it correctly without damaging the journals, and how to prepare it for storage. The journals are so easy to damage... but easy to protect with just a little effort.
    May 2014
    us, ga
    Default Need oil pump bolt
    Yep, I lost mine during the rebuild. Part #14028914 (11mm x 1.5mm x 66mm) Thanks in:cool advance
    Feb 2006
    Hollywood, CA
    Gone, sold some, scrapped the rest.
