Results 1 to 11 of 11
Thread: Missing magnet on spin on filter...
    May 2012
    Langley
    Default Missing magnet on spin on filter...
    Ugh, did transmission fluid. There was no magnet on the filter.
    Now I have to take it off and etc etc.
    No big deal but mildly frustrating.
    Last time I had my truck's Allison serviced, I brought the new filter with me, and mentioned the magnet to the tech as he removed the old filter....
    Quote Originally Posted by gary_lucas View Post
    A filtermag on the outside of the can is much more effective (larger and stronger and no need to clean when servicing. I run both.
    If you don't align the polarity of both magnets, they are close enough to cancel themselves and catch nothing. I'm not sure if that's even possible with a cylindrical vs. flat-plane magnets in close proximity. The Filtermag polarizes the filter canister, which may have some affect on the flat magnet and its effectiveness.
    Dec 2002
    Teton Valley, Idaho
    Could be an interesting test to strap on a filtermag and the OEM magnet and hit the assembly with a handful of iron dust. Then flip the filtermag and do the same thing. Then flip the OEM magnet and do the same thing again. Then flip the filtermag one more time so all configurations have been tested and hit it with the iron dust again. Really the only way to see if rolling your eyes is appropriate or not...
    Given that I'm sticking with the OEM magnet, I'll not be the one to run the test.
    May 2012
    Langley
    Talking
    Nice, I already bought the OEM magnet will put in shortly.
    The funny part was that when I was poking around in the gunk trying to figure out if the magnet had fallen into the transmission fluid catch pan I was thinking: "I wonder if you could slap a giant magnet on the outside of this thing..."
    Then Kennedy comes up with: "A filtermag on the outside of the can is much more effective (larger and stronger and no need to clean when servicing. I run both."
    Owego, NY
    Interesting question on polarity of the two magnets. One test would be to hold the OEM Allison magnet and Filter Mag in approximately the same orientation they would be on the filter and see if they attract each other. If not flip the OEM magnet and try again. The North/South poles of the OEM magnet should be the top and bottom of the disc and the poles of the Filter Mag bar magnets would be at the top and bottom of assembly. If that’s the case and assuming the poles of the two magnets were aligned, then the combined magnetic fields would be channeled through the filter case. The next time I change my Allison Filter I’ll test it out with a Filter Mag and report back.
    Bill
    98 K3500 6.5,SOLD
    The factory magnet is on a horizontal plane and has the thick steel base between it and the "can" of the filter. It is also a relatively weak magnet especially compared to the Filtermag setup.
    The filtermag magnets are on a vertical plane and I'd estimate 1/2" below the base and also outward by same or more.
    May 2012
    Langley
    Do you put filtermags on the oil + trans spin on filters? What about the transpan? (That's aluminum so probably not).
    Also, there was a square of 'sludge' that didn't come off terribly well when I did the pan. I just wiped it clean but didn't otherwise mess with it. I was more interested in not introducing new contaminants that dragging everything out.
    I run them on oil and fuel filters as well.
    The OE trans pan is steel with an aluminized type of coating. Filtermag does make a flat type for trans pans that I have used before. Inside the Allison pan is a small square of magnetic film like a flexible magnetic sign or refrigerator sports schedule is made of.
