Yes, for now. After you've been around a while, and interact more, you'll be allowed more features and storage space. Keep going at your rate and it won't be long at all.
Oh I see!
I picked up the donor truck today, there's lots of work to be done.
It didn't come with a cab or bed, just the rolling chassis.
I've got the bed taken off of the half ton, as well as exhaust, transfer case and everything.
All that is still connected is the front suspension + axle and the cab.
The rear axle is still on, but I plan on swapping the 3/4 ton axle into it today. It seems like it will fit perfect, just move the springs. There's less than a half inch difference between the 3/4 ton and 1/2 ton mounts, so with the play in the shackles Im hoping it will fit.
The donor truck was a 4 door short bed.. And I know that it's an option to swap the cab onto the 3/4 ton frame but that seems like a huge pita.. Cutting the frame and all that.. Then fitting cab mounts..
I plan on swapping a Dana 60 in, but for now I'm going to leave the half ton front.
If it had been fairly easy, I wanted to swap the 3/4 ton front suspension and diff and everything into it, but that doesn't seem like it will work either.
So I get to go with my original plan! solid axle swap.
I'll post some more so that I can post pictures...
It's no fun without pictures 👎
