Results 1 to 8 of 8
Thread: No rev limiter?
Hybrid View
    Jul 2017
    Default No rev limiter?
    My tranny shifts really late (or not at all) if I don't let up on the gas pedal.
    RPM goes waaay over 4000, even 5500 once when I was not paying attention.
    A while ago I gave my TV cable a little more slack and the shifting improved.
    I rode around like that for a few months but after reading a lot of stories about how you can ruin your tranny if the cable is not set right I adjusted it back.
    (pulled all the way to the firewall then hit the gas)
    Immediately the late shifts are back (duh) but it makes me wonder, shouldn't my IP limit my maximum revs?
    O and for the yearly emission test, they have to mash the gas for 5 seconds while in neutral, they almost blew up my engine!
    My revs really need to be limited, I don't think my car will survive another emission test.
    To begin, change the fuel filter and/or fix your fuel supply system shortfall (this fixes 99% of these complaints).
    If you are, in fact, seeing 4000-5500 RPM's, especially under any appreciable load, the IP is broken, or your method of measuring engine speed is highly questionable. The IP governs maximum speed, but reduces (tapers) fuel volume beginning about 3100 RPM's. Governed speed should never exceed 3600 RPM's. Late shifts at high RPM's is either a failed transmission, TV and/or cable, or you need to change the fuel filter. This assuming everything worked normally before something changed.
    Jul 2017
    I already replaced the fuel filter some time ago.
    I can repair the late shifts by adjusting the TV cable again I think.
    That leaves the IP right? Can I somehow check the governor or something?
    Simply, if the engine speed is exceeding 3600 RPM's (verified), then the IP governor isn't working. A failed governor is a broken IP.
    Even if you have a relatively fresh fuel filter, verify fuel delivery to the IP. Poor quality fuel can foul a filter quickly, and there may also be other issues with fuel delivery, including a failed/failing fuel lift pump, air leaks, collapsed fuel lines, or other restrictions. Any shortfall in the fuel delivery can, and usually does, cause tranny shifting issues. It's a simple matter of the engine power output (reduced) compared to the throttle (valve) position causing delayed, higher RPM shifts.
    Adjusting the TV cable to accommodate other issues can damage the transmission. Adjust the cable correctly, then correct other issues that cause problems.
    Jul 2017
    I checked the fuel delivery to the pump, I saw nothing out of the order everything clean and no leaks.
    Tried readjusting the TV cable and I found out that if I slide the slider all the way to the firewall it becomes stuck, it will not adjust when giving full throttle.
    So I tried again this time with the adjuster just a VERY small tad back and when moving the throttle lever to WOT it clicked so I assume it adjusted itself this time.
    Anyway the shifting is back to normal again, not too soft shifts not too hard and all at the right moments depending on throttle position.
    Still have that problem with the unlimited RPM's though so I'm going to have my pump checked or buy a new one.
    Jul 2017
    I talked to a friend who used to own a ex-military Chevy K30 and he had the exact same problem, his revs weren't limited either.
    When going through a emissions test he had to block the throttle lever with a piece of wood to prevent over revving the engine.
    None of you ever had this problem? I find it kinda strange I don't read anything about this on the diesel page and the only guy I know who owned a GM 6.2 diesel had it too.
    This must be a common problem, or is it the Dutch air or something in the water that make our pumps go crazy??
