Results 1 to 15 of 15
Thread: Oil filter reloacation
    May 2017
    Kristiansand
    Default Oil filter reloacation
    Can somebody recommand a good quality oil filter relocation kit? After having issues getting filter off I`m getting tired of this. I did a search here but it did not reveil much on what to use and ther`s a lot on the net.
    Still I don`t really feel the need to get the amsoil dualfilter bypass. Im okay doing more freqent oil changes. But relocating filter to frame or front of truck would work fine and most likely use standard oil filter.
    98 6,5TD Suburban 1500 4x4, 3" exhaust
    Jan,
    If you want a good filter but not the Amsoil you might want to look at Donaldson filters. Might have to find a truck parts supply to find them. Great filters and work very well.
    Feb 2017
    Buskirk, NY, US of A
    I do not have a relocation kit, but have found a sandwich adapter for an oil cooler. Could you do that and put an empty filter with a good sized magnet in it in place of the original?
    May 2017
    Kristiansand
    Jan,
    Filters should be no problem to get my hands on. Its more of a reliable oil filter relocation kit since the front axle is in the way. I need something that can last and not break down cus of cheap ebay quality.
    Quote Originally Posted by Nessmuk View Post
    Not quite sure what you mean but I do not like that idea..
    Every time I change the oil on either the K1500 or the K2500 I swear I’m going to do a oil filter relocation before the next oil change. After a few days I find more important things that require my attention - until the next time I’m laying there swearing at GM engineers once again…
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    I have an amsoil kit. Quality is great. I have removed and reinstalled on two different trucks and engines. Even if you dont think you need the bypass filter, it doesnt hurt anything. I know this kit is expensive, but IMHO it's worth it.
    It also gives you the ability to add and extra 2 quarts of oil by using the bypass filter and a large regular filter.
    I also know that JEGS and Summit racing have kits and adapters and other stuff for doing this as it is popular with racing.
    Good luck!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Ditto. I've been saying this for nearly 12 years now!!
    Sep 2006
    I agree 100%. I used an Amsoil bypass kit under the hood on my '94 and it was awesome. Install the petcock too so you can grab a sample for testing (~$25) and you'll know when to replace filters, oil, air filter or get rid of it. Oil sample history will help resale a ton too for maintenance records.
    1994 6.5 HO vin "F" X-cab, long box 4x4
    Phazer set installed, 97+ cooling mods with 9-blade fan.Turbomaster, gauges, OPS mods with selenoid and lift pump indicator light 4" turbo back open exhaust, remote dual oil by-pass, Amsoil 15w-40, remote PMD #9, battery mods, 98+ airbox, 3.42s w/ NV 4500 converted to South Bend SM system with damper installed, 147K.
    May 2017
    Kristiansand
    Quote Originally Posted by Dvldog8793 View Post
    Howdy
    Good luck!
    Thanks for feedback, gladly appreciated^^
    Sadly cost and shipment with customs here just kills what it is worth for :/
    I need to do something then
    Quote Originally Posted by 94bluehd View Post
    Sample test will cost to much money for me to ship oversea. I usually do a oil and filter change at regular basis. Amsoil seems to have the best kit with quality compared to some of the cheaper ones. But not sure which to choose. I can`t renember size of oil filter.
    Sep 2006
    I'm using one of these for my bypass filter. It uses toilet paper and filters the oil so well that it even filters out the black carbon.
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    Edahall
    Is that a Franz filter?
    My dad ran one on his truck for years.
    Sep 2006
    Edahall
    No, it's similar to the Franz but better constructed. It's a Model M-30 air compressor filter converted into an oil filter. It is much less likely to leak than the Franz filter and is exactly the right size for putting the entire roll of Scott's 1000 toilet paper.
    Here's a link to this filter. Filters down to .01 micron.
    https://www.amazon.com/Motor-Guard-M.../dp/B000GI0H2M
    -3.73 gears
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    Sep 2003
    Feeniks, Aridzona
    Quote Originally Posted by Edahall View Post
    What don't you like about the Frantz?
    How do you meter how much oil goes through the bypass?
    Sep 2006
    Quote Originally Posted by JeepSJ View Post
    I had a hard time keeping the Franz filter leak free. It had a tendency to leak around the bottom rubber gasket.
    Oil flow is controlled by an orifice.
    Sep 2003
    Feeniks, Aridzona
    Is the orifice part of the filter already or did you add something to it? I'm wanting to do a bypass filter and that looks like a great option, especially since it can just take a full roll of TP. So any other details you have on the install?
