Thread: Turbo Vane Position Sensor
    Sep 2017
    Delta, BC, Canada
    Default Turbo Vane Position Sensor
    Howdy Y'all...
    2005 GMC 3500, about 140,000 miles. Stock, owned since 2010 @ 40,000 miles
    About 2 years ago I lost all power and puked smoke an hour into a 5 hour drive home. Limped it home and checked codes. Code was Turbo Vane Position Sensor. Replaced it and it ran great until now.
    Last month, same symptoms, same code, as well as one instance of a code for the MAF. I had scanned a handful of times and the MAF code only came up once. Replaced the Vane Position Sensor, ran great for a day then crapped the bed again. Has run fine most of the time since last month but the same symptoms have appeared a couple times then gone away. The last 2 times I went to drive the truck, the symptoms were as bad as they've ever been. This morning it stalled 4 times on my block so I parked it and scanned for codes. No codes whatsoever. I ordered another Vane Position Sensor and just finished replacing it. Didn't work.
    Still no codes. Any ideas? Thanks, all!
    Brett
    Sep 2017
    Delta, BC, Canada
    Not 1 single idea with over 200 people viewing as we speak?.... I guess I found this website a whole lot more useful 10 years ago when I had my 6.5.....
    Dec 2002
    Teton Valley, Idaho
    Check the wiring harness for chafing?
    Loyal WI US
    Stalling would not be vane sensor related. I would start with fuel supply side particularly if you are running a black plastic fuel filter.
    If you are having turbo issues it could be a sticking unison ring. More common on LBZ and LMM but I did a tech tip outlining the internal part of the project:
    http://www.kennedydiesel.com/docs/Ga...20sticking.pdf
