Results 1 to 10 of 10
Thread: oil consumption
    Oct 2017
    Kokomo, Indiana
    Default oil consumption
    Ok, going thru oil just a wee bit on my 94 C2500. Daily driver to work, I can go from the full mark on the stick to an 1/8th inch above the add mark in roughly 200 miles thru the work week. Engine has 149K on it, age of injectors/pump is unknown. NO drivablity issues, idles smooth, starts easily, runs on all 8, even after sitting for 10 hours in 20'F temps at work. yes she has blow by out all the normal spots, no leakage to the ground of oil or anything else. Just goes thru it. Using Shell Rotella T 15w40, which has what I have used in every diesel I have owned. Do I just put up with oil usage and start planning to replace the engine next spring/summer or am I missing something. I tried with the CDR vented to the ground vs hooked to normal spot with no real change in oil consumption. With my extension tube, I see the vapor, but there is no liquid oil in the tube or on the part of the frame where I have it mounted. A recent 400 mile trip at highway speeds took her from full to just below add. I get in the upper teens for MPG's. Truck is emaculate, was owed by a diesel mechanic before myself, body is 98% rust free, only a few small bubbles in the bottom of one door. My usual go to place for a rebuilt 6.2/6.5L is nolonger a viable choice from my recent research(Diesel Depot/Avant Salvage). Just want to look at all options before things get worse, I could trade it off right now if I needed to, just do not really want to. But I cannot also afford any long down time due to failure as its my way to work. Thanks for any ideas in advance
    Silly NT's....I have Asperger's!
    1994 Chevy C2500 6.5td
    SSDiesel Heatsync
    4L80e built
    150K miles and counting
    Sep 2003
    Feeniks, Aridzona
    Valve seals.
    Oct 2017
    Kokomo, Indiana
    Doesn't help that I cannot find a shop localy that is famillar with this older engine, being the home town of Chrysler's transmission plants, most everybody drives Dodgers or something with a Powerstroke in it. My old truck is an oddity in the local diesel scene.
    SSDiesel Heatsync
    4L80e built
    Dec 2003
    Yukon Canada
    Next oil change try a different oil.
    KW dealer changed the oil in my Kenworth to a Rotella oil.It didn't like it,or should i say it loved it because my oil consumption doubled till it was changed out again.
    Rotella oil...it loved it because my oil consumption doubled till it was changed out again.
    Changed out for what?
    Oct 2017
    Kokomo, Indiana
    Yes, whats in the KW now? Trying to not go to a much more expensive full synthitic oil.
    SSDiesel Heatsync
    4L80e built
