Originally Posted by
Diesel Dan
Would like to get a manual wastegate so I can ditch the vacuum pump(original).
I installed the Turbomaster manual wastegate and ditched my vacuum pump. I love how it keeps boost constant and consistent. Just be forewarned that the ECM may not like losing control of the boost. My ECM would constantly throw a CEL and put the engine into limp mode after the install. I had to install a chip in my '95 (your 2000 will need to have a flashed ECM). Took two tries with the programming to get it right, but now she'll pull all day long without an issue.
