Results 1 to 6 of 6
Thread: Uncommanded full throttle
    Jul 2006
    Adelaide, South Australia
    Default Uncommanded full throttle
    My wife was driving my 6.5td last night. She went to accelerate the engine kept accelerating. She braked against engine managed to stop with the engine running flat out. It stopped when she turned ignition and off. Weather was hot. Has been threatening to do the same to me in the winter wet. When I got there 2 hours later started and ran fine. No stalling issues. Anything come immediately to mind? Has anyone had this experience before?
    Noel
    1998 (Badge Re-engineered)RHD GM-Holden Chevrolet Suburban K2500, 150k miles, Turbo Diesel 583Nm 200Hp, New 4L80E, 3.73:1, Rebulit T/case with New Housing, standard 245's factory 6.5" wheels. No Mods. Car Code OBDII interface with Enhanced GM data, test & command modes, data logging, live data etc.
    Toyota HZJ80 Landcruiser 4.2L Turbo Diesel, 195k miles, 430Nm 210Hp. Mitsubishi Water Cooled Turbo, Through bonnet Intercooler, Advanced timing and increased fuelling, 12 psi boost, Boost gauge and post Turbo pyrometer. 5 Spd Manual.
    Feb 2012
    Pauline, SC
    Sounds like the PMD is on it's way out..
    1993 Chevy K3500
    like us on Facebook
    Jul 2006
    Thanks that's what I had been thinking apart from TPS. I have a remote mounted grey Stanadyne FSD. it's about 8 years old... appreciate the feedback.
    Noel
    That is the most rare of the PMD failures.
    Starting the engine in this condition will see it rev past red line and the ECM will shut it off.
    Glad to hear that no body was hurt or rigs wrecked.
    Turning off the key...even in gear (LEAVE IN DRIVE) and coast to the shoulder..
    Replace the PMD with a Flight systems PMD mounted on a cooler on the top side of the radiator skid plate...
    Use extension cable that will fit the Flight systems unit
    If you don't know what resistor is in the PMD plug on the PMD and its on the IP use a #5
    Jun 2000
    Arlington,MA U.S.
    The pump was bad on my 98, same symptoms. Tried the PMD first and same results.
    Yeah, if the fuel solenoid sticks open you get the same symptoms.
