My Buddy has a 1992 6.5 T/D. He has a break on one of the fuel lines. He just told me that the later model fuel lines are too big on the pump and injector sides, he tried using 1998 fuel lines.. Any suggestions on compatable year models?
His 1992 has a mechanical DB2 injection pump. He needs to look for fuel lines for 1992 to 1993 model years to be an exact replacement. In 1994, the DB2 was replaced with the electronic DS4 in most applications, which does, in fact, use different injection lines. However, the DB2 was continued to be used on vans and some other applications, so finding a donor engine with 6.5L injectors and the DB2 mechanical pump is what he wants to look for.
He might be also able to use older fuel injection lines, providing that the 6.2L engine they come off use short body injectors like the 6.5L does.
I doubt anyone is going to break a set for one line...
They can be found as single's on ebay also...
1993 Chevy K3500
like us on Facebook
Never used these but:
http://usdieselparts.com/c-778296-ch...6-2l-6-5l.html
http://www.hdiesel.com/P/LLInjectionLine6/1136
http://www.ssdieselsupply.com/p238_6...set_92_93.html - don't know if they would break the set or sell singles.
DP member #38 1992 Chev K2500 RPO C6P 6.5TD 150K miles
2014 John Deere 1025R
I checked my spare parts. I have a #5 and a #7 mechanical line and 2 full sets of EFI lines. Sorry, no #6....
Contact Me
Content Web Site
Photo Album
TDP Youtube Channel - New!
