Results 1 to 7 of 7
Thread: Transmission
    May 2012
    Langley
    I've had a p0700 previously, but just shut it down and started it up. Hasn't happened since (about 4 years).
    I would definitely get that into a shop (or if you're competent with a code reader etc do it yourself).
    Something is definitely not right. One thing I like about the edge module is that it includes a basic code reader / reset which is always plugged in and ready to go!
    I'm assuming you've checked your fluids and nothings low etc and all that obvious stuff.
    I hope it's something simple!
    Dec 2002
    Teton Valley, Idaho
    the #7 injector... Way back against the firewall.
    I wonder if whoever did the job either knocked an electrical connector loose or had to unplug one to gain access but forgot to plug something back in?
    #7 is the rearmost on the passenger side of the engine.
    When was the transmission last serviced (mileage on current service)? Otherwise, I agree with others here. Have the codes read. It'll help narrow the possibilities.
    Feb 2018
    Tampa, Florida
    Would strongly suggest that as well.
