Hi Jim,
Thanks for that response. I had read the first linked piece, but not the second one. The Sticky thread and John's tech piece rounded out my major research.
The bottom line seems either to be that this generation of injectors is vulnerable to wear and/or fuel viscosity changes, or the ECM programming is dysfunctionally narrow. (I include the latter because John seems to have attacked it somewhat successfully from that angle.)
My hoses, filter housing and filter have been replaced. The injectors all are strong in every test in the shop. The pump is putting out per spec. My GM guys have checked the cooler and lines, and I will do that again when I get some decent weather. (We just talked this morning about the possibilities of an auxiliary fuel cooler.) But there is no way to get them involved in more useful testing 200 miles into a day, going up some big hill towing a 12k trailer -- duplicating the problem with prolonged, sustained load and elevated temperatures. I can drive it all day unloaded in any weather, with no problem.
You know I love GM products. But pickup trucks built to work -- as our diesels are -- surely could have more longevity built into key, very expensive parts. Or is this the unavoidable legacy of always-advancing emission requirements and associated engineering compromises?
Color me frustrated and mildly disapointed...
Rich Phillips
Member #27
2019 K-2500 Crew Cab Z71
