Results 1 to 8 of 8
Thread: suburban proportioning valve
    Dec 2009
    In the North
    Default suburban proportioning valve
    brakes are awful on this burb, (99 c2500) new to me last fall,
    there is talk of an updated proportioning valve,. also using a 2002 master cylinder
    Has anyone here done either mod?
    if the truck was a 4x4 i could use later model brakes with bigger rotors and better calipers,. but i have 2 wd,.
    thanks for any help
    1999 chev suburban C2500
    300,000 mi
    What I used to do was run a cast iron MC off say a 1984 6.2. The proportioning valve does not let the rear brakes do much of anything. I believe the way this was done was to use a prop valve from a 1 ton wrecker type vehicle that was "open" to the rear, but it's been so long now.
    Maybe Ron Schoolcraft remembers?
    Feb 2012
    Pauline, SC
    You should be able to use the MC & prop valve from a 1ton. The HD MC's are for rear disc and they have a bigger bore piston & a disc prop valve.
    1993 Chevy K3500
    like us on Facebook
    I checked and RJ did not do it to his. Howie may have done it or maybe Jim Glus. Glus was yacht4u or something like that. Admin may have a better way of narrowing the search. I'd wager that the part number was posted here at some point 15+ years ago...
    Possibly 12548265
    Possibly 12548265
    That part number shows only in this thread/post. Nowhere else.
    Search (advanced: click search at the top of the page, then "advanced search") for "proportioning valve" in all open forums, with no other terms. Any added terms narrows the results too much. Set the "show results as" to threads, rather than posts to help weed through the irrelevant posts. I got hundreds of hits (posts) that date back to 2003.
    I'm guessing that 2003 was a forum software change date and that much of this discussion fell prior to that. I reached out to a GM tech friend and previous owner of same era trucks hoping that he recalls the bulletin.
    To me the cast iron MC made a huge difference.
    RockAuto shows a variety of part numbers for the '84 K20: https://www.rockauto.com/en/catalog/...+cylinder,1836
    Is there something specific that one would be looking for?
    Default Part number confirmed
    12548265 proportioning valve.
    18029651 shoes
    This was based on vehicles with the big 13" x 3.5" rear drums, but likely works with others as well.
