Thread: Dmax to NV4500
    Sep 2003
    Feeniks, Aridzona
    Default Dmax to NV4500
    Anyone done it? I've spent a lot of time searching and have found a few threads from people who said they were doing it, but then no conclusions or follow-ups. Why? Because the NV4500 fits the R30 chassis nicely and the ZF6 doesn't (and I own a NV4500 and the ZF6 is stupid expensive). Was originally going to swap in a 6.5, but I'm now leaning towards Dmax.
    Thoughts?
    Are flywheels, pressure plates and clutch plates available for the Duramax?
    If so, the question becomes, do the NV spline and pilot match?
    Once those questions are answered, we know that the ZF and the NV both have a somewhat lower torque limit than the Allison. Torque needs to be kept within the 650 lb-ft torque limit of the ZF, which is likely close to the limit for the NV.
    Sep 2003
    Feeniks, Aridzona
    Standard DMax flywheel and pressure plate, and disk with spline count to match the NV.
    Not worried about the capacity of he NV - guys are using them in pullers behind built Cummins. Yes, the Cummins version has a bigger input shaft, and there are upgraded input shafts for the GM application transmissions. I'm also not going to go crazy with the Dmax power, nor do I plan on racing.
    Feb 2012
    Pauline, SC
    I do know Humvee guys are using Allison trannys behind the 6.5, not clear what all is involved tho... lots of them on the humvee forum...
    1993 Chevy K3500
    like us on Facebook
