G/Day guys, the DB2 injector pump what is the make & the correct part No, also what is the part No for hi flow injectors.
Cheers
Cheers
OKA 4X4 NOW HAS 6.5 TURBO + 4L80E <br />HOLDEN MONARO / GTO PONTIAC LS1<br />HOLDEN / ISUZU RODEO CREW CAB 4X4<br />QUINTREX 6.1 / 130 HONDA
For the pump numbers, try
http://www.thedieselpage.com/members/pumplist.htm
Maybe someone else can help with the injector numbers.
'94 Suburban 2500 6.5L 2WD Trailer RPO
'89 Reg. Cab 2500 6.2L 2WD Manual 4sp
'83 Suburban 1500 6.2L 4WD 700R4
'83 Blazer 1500 6.2L 4WD 700R4
Miscellaneous Gassers
High Flow Injectors are aftermarket.
Try Kennedy Diesel or Bill Heath Diesel. Both of these gentlemen are vendors here and members also.
Charlie P. <br />95 Tahoe 6.5 TD
