Results 1 to 6 of 6
Thread: Using a cleaner in the oil...
    Dec 2005
    Klamath falls/keno Oregon
    Default Using a cleaner in the oil...
    I’m going on a 9 hour trip soon..I have 400,500 miles on a stock engine....what would be the pro’s and con’s on adding a engine cleaner in the oil for that trip and changing the oil at the destination. I use Amzoil.
    Thoughts??
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I personally would not add anything that dilutes the oil and then go on a long trip...
    If you've been using Amsoil, or any high quality synthetic, of the proper grade and weight, you've never had overheat episodes, and you've been diligent with service intervals, I say no. It simply won't be of any benefit. The high-miler's I've been inside of were fairly clean, very much unlike the 100K mile engines of old. Most "cleaners" recommend driving 100-200 miles before changing it out, so a "long" trip may be too far/long. At most, I'd add the cleaner at the last 100 miles of the trip, then change it, if you're set on using it. I don't think it would hurt anything, but the benefit may not outweigh the inconvenience and mess.
    Dec 2005
    O’tay..not doing it...thanks
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Back in the 1960s when I began wrenching on my "cars of many colors" (red fender, yellow hood, black top, etc), seemed like every engine I worked on had a buildup of scum inside... layered inside the valve covers, all around the valve train and a thick layer of muck in the oil pan.
    Nowadays, thanks to modern engine oil, that just doesn't happen in a reasonably well serviced diesel engine. They stay really clean.
    Knoxville,Tennessee
    Might be the cleaner burning and less gas washing the cylinders into the pan has something to do with it too.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
  1. How Do I Verify Oil Pressure?
    By DennisG01 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-30-2008, 01:01
  2. No Oil Pressure After Oil Change (long post explaining my proceeder.)
    By wthif in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-02-2006, 05:47
  3. NEW TDCO procedures?
    By Aryeh Levy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-25-2005, 06:51
  4. Don't trust tech's changing your oil !!!!!!!
    By mackey_62 in forum Duramax 6600
    Last Post: 06-13-2002, 13:06
