Originally Posted by
More Power
I watched an ARP video a while back where they discussed the "elastic" clamping load supplied by properly installed and torqued Series-2000 head studs produced for the Duramax. I like it that the ~$650 head studs have some elasticity designed-in.
However, we know that GM is still using TTY bolts in the newest L5P Duramax, which is rated for 445 hp / 910 lb-ft - and rated for up to a 35,000-lb GCVWR.
I interviewed the "Duramax Power Tour" team in 2000, who drove an LB7 equipped 3500-series truck towing a 20,000-lb event trailer. I rode in that truck as they wailed on it, on the I-90 continental divide pass just east of Butte, Montana. I asked them if they drove it like that all the time. I was told yes... They put in excess of 20,000 miles on that truck - hammer down all the time. I can also point to a 750,000-mile LLY Duramax used to commercial tow RV trailers all over North America, that I wrote about a few years ago. GM could acquire head studs equal to those offered by ARP (maybe even contract with them to provide) if they felt it was necessary.
I have a couple of debate points about studs that are hard to answer and difficult to challenge. 1- The aftermarket pushes anything that they can sell - ("while you're in there") type of stuff, including head studs. 2- Studs are simply easier to install than TTY bolts. You must mark the heads of each TTY bolt during the two angle tightening sequences or you'll mess up the installation. With studs, you only use a torque wrench. If you forget one or get out of sequence, it's really easy to check what the torque is for that stud. Personally, I think this is why many vendors/mechanics push studs (sell more expensive stuff and they are easier to install). Otherwise, they would/could point to actual durability tests involving direct comparisons between engines using head studs and TTY bolts (fleets would be the best source of information. Second best would be an accumulation of real-world reports from actual owners - like the story I did on the 751k mile LLY Duramax). For most, these head gaskets will wear out long before any real comparison can be done on the veracity of claims otherwise.
I have the opportunity to purchase some new ARP head studs for my 6.5L for the same cost as new TTY head bolts. Is there any reason NOT to use head studs in my application? This is a stock 6.5L with 375K on the clock and no other issues other than a blown head gasket. John Kennedy recommends studs.
Thanks,
