Thanks!
Thanks!
I would like to make a little comment, it is not good to run pumps dry, it will shorten the life of the impeller.
Part of the fleet.
85 Sub. 6.2 trans out.
82 3/4 CC 6.5 N/A
83 GMC 1 Ton 6.2 Est Mil. 1 MIL +
96 Dodge 3500 5.9 4X4 Sorry, went to the dark side.
19 Escalade Buick
That is correct!
https://www.pentair.com/en-us/produc...ntair_products
"Can run dry without damage."
I stand corrected, but my old camper has a pump with impeller.
Part of the fleet.
82 3/4 CC 6.5 N/A
19 Escalade Buick
