Results 1 to 6 of 6
Thread: I was sniveling about..
    Dec 2000
    Hawaii/Arizona
    Spongebob, On my 06 LBZ I had a leak that appeared to be above the oil filter. It was actually the coolant hose to the EGR cooler. I was not happy with GM when I found a standard 3" long 5/8 heater hose was stuffed in the HOT valley between the heads. I replaced the hose with a piece of CAT sylicone hose. 22 dollars for one foot at the CAT dealer. I would check that hose for a leak before tearing anything apart.
    Good luck
    John
    *2007 Pontiac Solstice.
    Dec 2005
    Klamath falls/keno Oregon
    any chance you can get a picture of said hose??
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2005
    the hose leaks.....
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2000
    Hawaii/Arizona
    I am glad that you found the problem, now comes the fun part. That little hose is hard to replace.
    Good luck
    John
