Sounds goofy to me. Maybe there was a history code (bogus) for the fuel temp fault. Now you mentioned pressure and temp sensors in the same paragraph, so keep that in mind.
Anyhow, the latest updates address false codes, and I am told that when one digs deeper, the update involves the bogus fuel tmp sensor codes. I would twist his arm to update, and then see what reoccurs...
