Results 1 to 8 of 8
Thread: DTC Codes-Definitions
    Aug 2003
    Wausau, WI
    With alot of members having a tuner that can read codes, I thought it would be nice to have a guide to cross these codes to see what they mean. I am posting the more popular ones relating to engine and trans. Keep in mind there are hundreds more codes lot listed.
    I can look up any code instead of calling the dealer.
    List:
    DTC C0323 T-Case Lock Circuit Low
    DTC C0324 T-Case Lock Circuit High
    DTC C0550 ECU Malfunction
    DTC P0087 Fuel Rail Pressure (FRP) Too Low
    DTC P0088 Fuel Rail Pressure (FRP) Too High
    DTC P0089 Fuel Pressure Regulator Performance
    DTC P0090 Fuel Pressure Regulator Control Circuit
    DTC P0093 Fuel System Large Leak Detected
    DTC P0094 Fuel System Small Leak Detected
    DTC P0101 Mass Air Flow (MAF) Sensor Performance
    DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
    DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
    DTC P0168 Engine Fuel Overtemperature
    DTC P0171 or P0174 Fuel Trim System Lean
    DTC P0172 or P0175 Fuel Trim System Rich
    DTC P0181 Fuel Temperature Sensor Performance
    DTC P0182 Fuel Temperature Sensor Circuit Low Voltage
    DTC P0183 Fuel Temperature Sensor Circuit High Voltage
    DTC P0192 Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage
    DTC P0193 Fuel Rail Pressure (FRP) Sensor Circuit High Voltage
    DTC P0200 Injector Control Circuit
    DTC P0201-P0208 Injector Control Circuit
    DTC P0218 Transmission Fluid Overtemperature
    DTC P0230 Fuel Pump Relay Control Circuit
    DTC P0234 Engine Overboost
    DTC P0236 Turbocharger Boost System Performance
    DTC P0237 Turbocharger Boost Sensor Circuit Low Voltage
    DTC P0238 Turbocharger Boost Sensor Circuit High Voltage
    DTC P0300 Engine Misfire Detected
    DTC P0301-P0308 Engine Misfire Detected
    DTC P0325 Knock Sensor Module Performance
    DTC P0327 Knock Sensor (KS) 1 Circuit
    DTC P0380 Glow Plug Feedback Circuit
    DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
    DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
    DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
    DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, or P1683 ECU Malfunction
    DTC P0611 Fuel Injector Control Module Performance
    DTC P0612 Fuel Injector Control Module Relay Control Circuit
    DTC P0740 TCC Enable Solenoid Circuit Electrical
    DTC P0741 TCC System Stuck Off
    DTC P0742 TCC System Stuck On
    DTC P0748 Pressure Control Solenoid Circuit Electrical
    DTC P0751 1-2 Shift Solenoid Valve Performance
    DTC P0752 1-2 Shift Solenoid (SS) Valve Performance - No Second Or Third Gear
    DTC P0753 1-2 Shift Solenoid Circuit Electrical
    DTC P0756 2-3 Shift Solenoid Valve Performance
    DTC P0757 2-3 Shift Solenoid (SS) Valve Performance - No Third Or Fourth Gear
    DTC P0758 2-3 Shift Solenoid Circuit Electrical
    DTC P0763 Shift Solenoid (SS) 3 Control Circuit High Voltage
    DTC P0768 Shift Solenoid (SS) 4 Control Circuit High Voltage
    DTC P0773 Torque Converter Clutch (TCC) Enable Solenoid Control Circuit
    DTC P1125 Accelerator Pedal Position (APP) System
    DTC P1172 Sec Fuel Pump Insufficient/No Fuel Flow
    DTC P1258 Engine Coolant Overtemperature - Protection Mode Active
    DTC P1261 Injector Positive Voltage Control Circuit
    DTC P1262 Injector Positive Voltage Control Circuit Group 2
    DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
    DTC P1550 Fuel Injector Control Module System Voltage
    DTC P1643 Wait to Start Lamp Control Circuit
    DTC P1658 Fuel Injector Control Module Driver Performance
    DTC U1800 Lost Communications With Fuel Injector Control Module (FICM)
    DTC P1870 Transmission Component Slipping
    Maverick
    2005 GMC 1500 Crew Cab SLT-I know, its a gasser....
    Nov 2002
    Mobile, AL
    Here bud, use this link as well, as it can prove to be very useful!
    http://www.autotap.com/codes.asp
    Sincerely...
    FYI the code reader in the review linked below will display the actual description making life much easier. There are less expensive readers out there, but most do not include the description which is why I chose this model:
    http://www.thedieselpage.com/reviews/quicklynks.htm
    Default codes
    im reading a
    PO380
    PO621
    any ideas what to do or check?
    Quote Originally Posted by hrsedrvr View Post
    im reading a
    PO380
    PO621
    P0380 indicates a problem with the glow plug system. P0621 - GEN Lamp 'L' Control Circuit, which may indicate a problem reading the alternator control circuit.
    Both of these codes indicate an electrical problem. Bad alternator, bad batteries, loose connections or bad grounds could be a problem.
    kind of like a needle in in a haystack deal,lol
    anyone ever have these codes and find something?
    to give me a place to start looking
    Jan 2006
    South Milwaukee, WI
    Angry P10D1 code
    My '17 DMax (L5P) is showing a P10D1 code. Not finding much on it, other than it might be related to the DEF system. (The little I found about it also mentioned a P20EE code, but I'm not getting that one).
    Anyone have any ideas? I just dumped a jug of Blue DEF into it this past weekend. I've got less than 300 miles on it since and the engine constantly goes into the regen mode. I figure I've sucked up nearly 1/8 of a tank of fuel due to this (according to my fuel gauge). NO check engine indicator has come on- I'm seeing it listed using my Edge monitor.
    "Chessy56"
    So. Milwaukee, WI
    '01 2500HD, LB7, ~440K miles
    Winston Churchill
    Ft. Wayne, In.
    While I like to diddle with my own stuff, I'd have that rig in the dealer shop right now while it's still on them. But that's just me.
    Dave
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
