AC Delco 60G GP's = 445, 0 100 271 107 10.5v
Ok my truck has been starting slow and with a big puff of white smoke. Today it did not want to start at all. Tried the drivers side front glow plug and its dead reads open but it looks ok. A little wet from trying to start so I figure thats it bad glow plugs (I think I stressed them over torqued when I put them in last fall I mistakenly set torque wrench to 25 ft lbs instead of 12 ft lbs).
So I went to Chevrolet dealer to get some new glow plugs and wanted the AC 60G's because those are suppose to be the "tougher" ones that don't swell and you can extend glow time. But may heat slower than my 97's OE plugs.
The 8count box says 8#60G 12563554
individual box says 60G and upc 0 21625147192
On the plug itself below threads it reads
AC Delco 445
0 100 271 107 10.5V
Are these the preferred glow plugs. I would have thought 60G would have been on the plugs too.
Note a local Stanadyne shop had some made by Lucas (he said same as Delphi) but I querried lucas and saw where Jim had tested some and the Lucas had some tip swelling.
