Results 1 to 8 of 8
Thread: Transfer Case Problems
    Cornelia, Georgia 30531
    Thumbs up Transfer Case Problems
    Hello to all. It's been a long time since I've contributed anything to the forum. I have a 2001 GMC Duramax/Allison with 160,000 miles. It's had a few problems along, mostly fuel related which have all been satisfactorily taken care of by the dealer. This time the dealer went beyond what I thought was reasonable.
    My transfer case went out. The dealer said it was completely dry. A new case and labor was just less than $2,000.00 and a 2-3 week delivery. I started thinking about what was the best course of action. My first thought was to talk to the service center where it has been taken care of since new. I asked them if it was within the normal service to check the fluid level in the transfer case. The guy I've known all my life and owner called the grease monkey on the carpet. I'm still not sure if he'd ever checked it because he was about to go to a place he didn't want to be in with the owner. In other words, he may have lied out of it.
    Anyhow, I started an internet search of a rebuilt unit and started getting a hint that there might be a porosity issue with these units. Come to find out, the dealership mechanic said he found a pin hole. Now I had some ammo to work with. I called the service rep at the dealership with my info and he said he'd look into it.
    Darned if he didn't call me back and said GM would replace the transfer case under warranty if I'd pay for the labor. $315.00 and less than a week I was back on the road. This post is really nothing more than to openly thank Jim Hardman GMC/Pontiac in Gainesville, Georgia and Chris for a great job.
    Herb
    2001 SLT DuraMax/Allison CC 4X4 SB White/Charcoal Valentine One, Bilsteins, Pendaliner, SPA Gauges Weatherguard mats, Kennedy headlight harness. Boston Accoustics speakers.Jordan Ultima. Edge Juice 4.61, Viper 790VX security w/remote start<p>2001 Sierra 3500 Duramax/Allison w/Knapheide service body.
    Jan 2003
    maui, hawaii
    Nice to hear positive news.
    1) '03 GMC 2500HD Dmax/Ali Ext/Short 4x4; 4" exhaust, egt and boost gauges; exhaust brake; Bilsteins; BD exhaust manifold; Oil Guard bypass; Lubrication pre oem fuel filter; Tekonsha Prodigy; Mag-Hytec differential cover; Suncoast V transmission w/deep oil sump
    2) '07 Classic GMC 2500HD Dmax/Ali Ext/Short 4x4'; Bilsteins, Silastic shackles, BD exhaust manifold; Oil Guard bypass; Lubrication pre oem fuel filter; Tekonsha Prodigy; Federico sway bars; Dipricol boost and egt gauges; Transgo Jr,, Mag-Hytec differential and transmission pan
    Dec 2005
    Klamath falls/keno Oregon
    WOW.... thats almost unheard of..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
    Feb 2003
    Holland, MI
    Unfortunatly, its not unheard off. It appears to be a quite common problem that plagues the magnesium case units found pretty much from 1998 and up on most GM trucks.
    The problem is as simple as 2.00 clip breaking.
    The clip holds the pump in the case from much movement and when it breaks, the pump is free to move and eventually wears a hole in the case causing the leak. If it goes to far, the leak can drain the case and you may never even know it, at this point, its usually beyond repair.
    There is a fix for this problem though.
    Dec 2001
    Nampa,Id USA
    Default 2500HD/3500 Trucks, Transmissions & Drivetrain
    Quote Originally Posted by dmaxalliTech
    dmaxalliTech,
    Can you tell us, what is the fix, does all the shops do it, & how pricy is it?
    chipper 2001 GMC,,D/MAX,SLE,EXT CAB,LONGBED,LINEX,FIRESTONE AIR BAGS,,driv\'en it & smilling, 32' Excel 5er
    Feb 2002
    Boerne, TX
    Smile
    Yeah, don`t just tell us there is a fix without telling us what it is. PLEASE !!
    Jomar
    2002 Chevy D/A LT 4x4 EC LB Indigo Blue
    Ranch Hand Grille Guard
    Stock Air Filter Rancho 9000 Shocks
    Luverne STS Boards
    Bestop Electric Towing Mirrors
    Husky Floor Mats
    Reese 16K 5er Hitch
    Amsoil all the way
    Dynomax 4in. exhaust system
    Egt & Boost Gauges
    OD Lockout
    Swiss cheese airbox
    Jul 2000
    Gilroy, California, United States
    That is unheard of, the dealer replacing something out of warranty. Perhaps since it sounds like the fact that you had the truck serviced there regularly was the tipping point. I had the same t-case leak and the dealer told me I should have bought an extended warranty, of course I do all of my own servicing too.
    I paid my local GMC dealer $100 to JB weld my case, thats the GM protocol fix. They got it wrong twice, second time was free because first time didn't hold more than a year. I have since used cold weld on it and it has stopped leaking.
    mattb5150@hotmail.com
    1993 K2500 HD ext.cab 4x4 - SOLD
    2003 GMC K2500HD SLT EXTRA CAB/SB DMAX/ALLI, Bilsteins, Sulastic Shackles, Pitman & Idler braces, KD Headlight Harness, CAT filtration, Lift pump w/KD harness, Denali Door handles, Yukon exterior mirrors
    2003 Yamaha Grizzly 660 Stoopider FAST
    1996 VW Passat TDI 48mpg - SOLD
    Aug 2006
    Sunny So. California
    Default Need Help with GM on this Problem
    Hello, I'm working with GM on this exact problem right now and was wondering if there are any more success stories out there. If there is anyone else that has had GM cover this repair please post ASAP. Thank you in advance!
    Have a great day!
    Chevy 2500HD Riding High
