OK, I finally changed my oil at about 3K+ miles and there was about 1 tablespoon of very dark thick ?oil? in the Crankcase Vapor Condensor jar. The engine oil was definitely dark (black actually) as well but not nearly as dark or as thick as what was in the condensor jar. So it did actually condense at least some of the vapor. And I have now made several improvements since I see that it does work at least somewhat.
Back to the oil change. I added a can of engine flush and followed the directions before draining the old oil and changing the filter. I then added 8 quarts of Shell Rotella and drove the truck for a couple days. Drained this oil hot, replaced filter and refilled with Shell Rotella synthetic and am using a Duramax oil filter (slightly larger - fits well). After a few days of driving the oil is still totally clean.
I have plumbed the CDR directly to the center of the Condensor and added a 1.5" stack of BBs in a 3/4" to 1 1/4" coupling to this intake as well. I stuffed a steel scrub pad into the outlet pipe plumbed directly to the stock adaptor plumbed into the stock intake just before the turbo and just after the air filter.
The extra elbows I had to use for the above connections resulted in a loss of vacuum at idle, remember, it was only 0.5"WC at idle anyway. At idle I now have about 0.5"WC PRESSURE measured at the dip stick. At 1000 RPM, I have about 0.0"WC and at 1500 RPM I have about 0.5"WC vacuum. Now, I will have to observe my oil color and maybe check the condensor jar at about 1000 miles into the oil change. Time will tell all!
Sorry I do not have the final answer yet but this is a try and see type of project. I will keep posting as I have additional info. It will be interesting to see what collects in the sludge jar since I am using fully synthetic oil now. Some of what I have read is that it is the light volatile parts of motor oil that boil off and collect in the sludge jar but, my Ranger below proves there is more that collects in the jar!
Future Improvements:
I may need to add an electric vacuum pump in the future (as suggested in a previous thread) to create enough vacuum at all speeds. Will need to keep the vacuum low though. Or maybe a larger connection to the stock intake ahead of the turbo. The current one is, I believe about 3/8" - a 3/4" would be a 4X increase in the cross section area and flow. Will just have to wait and see.
1992 Ford Ranger 3.0L Gaser with Crankcase Vapor Condensor:
Here is some real good promising news! There is about 4K miles on the current oil and it is only slightly discolored! A dark honey color! And this truck used to have the oil very black by 3K miles! It definitely works on gasers!
