From Mobil's website:
http://www.prod.mobil1.com/index***p
Do edit/find-
<< 06/17/2002 Bypass Oil Filtering
I read through the archive but could find nothing on "bypass oil filtering." I'd like to add the Oilguard System to my 1995 Ford F-150 with 50,000 miles. The literature and reports of performance of this type of system are quite positive. I've been using Mobil 1 in all my vehicles for 20 years and plan to continue that use. Has Mobil done any tests or does it have any recommendation regarding bypass filtering?
-- Paul Edstrom, Stanchfield
The average conventional spin-on filter for an automobile typically has a 40-50 micron absolute rating. That means particles larger than this size will be caught by the filter element. The Mobil 1 oil filter has a 15 micron absolute rating. Some bypass systems are rated at 1-3 microns absolute. We have not done any performance testing with the bypass oil filtering system you have suggested. Although a good filter is vital to the health of an engine, bypass oil filtering systems are capable of extremely fine filtration. It is usually not necessary to filter an engine oil down to cleanliness levels below the 10-15 micron range. We do not recommend filtering an engine oil down to below 1 micron particle size. Below this size, a filter may begin to capture vital components of the additive package. >>
Who wants to start with additive component micron size? Are they all below 1 micron and could a very efficient by-pass filter pick up some of the components? Seems possible.
It appears that if you use this system you should do on-going oil analysis.
[ 02-16-2003: Message edited by: TraceF ]
Trying to fill in the *** from the Mobil page address- put dot,j,s where the *** is.
I got this from the OilGuard website:
Sub-micron filtration does occur within the OilGuard bypass filter, and possibly within other competitive bypass filters. But this sub-micron filtration is a natural adhesion process of contamination simply sticking to the filter, much the same as dust sticks to the screen of a window. The filter is not trapping sub-micron particles, it is merely collecting them without any rate of regular consistency. To claim nominal sub-micron filtration would require proof that a filter can trap 50% of ALL sub-micron particles within a single pass. OilGuard knows of no such bypass oil filter which can achieve this.
[ 02-17-2003: Message edited by: TraceF ]</p>
