i had the dealer change the oil and asked them to check the cabin filter and they said it did not have one. are they right? its a 2001 2500 hd 8.1 5 speed allison 4x4 with L.T. trim dave p
2001 2500 hd. long box, club cab, LT. trim 373 rear end 8.1 gas engine 4x4, allison transmission
Yes
Look under the passenger side of the dash. Ask others and do a search for pics.
Burner
just a tip from a not to pleseant experience, if you do have one and your unit is covered with a plastic housing that runs from wall to wall, it will be held in place by 3 screws, strongly recommend you loosen, do not remove the left (nearest to the center of the vehicle), took mine out and have never been able to get it back in ........ Jim
\'02 3500 CC HD 4X4 LT D/A, Charcoal Gray Metallic,Juice 4.61, Loaded from end to end and most places in between
JEBar, I'm with you. That same darn screw took 80% of the time to change those 2 filter. Just about gave up, but was afaid it would rattle me into the funny farm. Just as a side note, the stealer told me that there was only one filter under there so for that 40 bucks I would have 2 changes. Shows what they know. I guess they never read their own manuals.
02 2500HD LT Dmax/Alli CC 4x4 Lt Pewter, Tan in, Amsoil, transynd, Bilsteins, Amsoil Air Filt, JK 4\" Exht, RollnLock, Rhino Liner, Remote start, alarm, High Idle, SPA DG211, Pred, Mega, Fumoto, Remote oil bypass, XL Tranny cooler, XM, Cell kit
The stealer would figure it out I would hope when they open the box and find two filters ....... CF 104-AC 52485513....All right maybe....
MAC
[ 10-20-2002: Message edited by: mackin ]</p>
Guess what [img]tongue.gif[/img] Napa has figured it out! They take the "two" filters and repackage them into "two" boxes. The nerve !
I guess it just burns me.. [img]tongue.gif[/img]
Burner
2003 GMC SLT CC 4x4 SB-Cooper Tires-Speed Liner-Activator II-Full length ICI SS step bars B&W Goose & more to come
-- Member #7527
E-Mail -->Twomuchplay(at)AOL(dot)com
In my $10 operators manual it states that if you do not have air conditioning there isnt a filter.
I had the same problem with that 3rd screw, it is now a spare part.
GMC 2002 DURAMAX, SLT, EXCAB SHORT BOX 2500HD, 4X4, AUTO
ACCESS TONNEAU COVER, 3" STAINLESS TUBE STEPS
JORDAN BRAKE CONTROLLER
34ft 10,000 lb TRAILER, 50 GAL TRANSFERE FLOW TANK (total 76 gals)
If you don't have A/C then you don't have the filters. The owners manual does not show the big black covering that must be removed first. This cover is on all LS and LT models but not on base I think. After the cover is removed, there is an L-shaped bracket with a screw towards the firewall that must be removed. When you remove the bracket you might want to have a cover over you floor because alot of trash and leaves are sure to fall. There are two filters in there side-by-side. I bought the filters from a dealership and they both come in one box. The screws on the cover are difficult on the hump side.
Hm. I'm gonna have to double-check. I only recall there being one filter in my truck.
Of note, I didn't want to spend the dealer amt for the filters, so I put in an off-brand. After me getting headaches and my buddy feeling nausiated, I took out that single filter and put in a single GM filter (in the box of 2). I'm sticking with the GM stuff for this.
Also of note, no problems with that 3rd screw. When putting that plastic housing back on, I just started with that one, then put in the other 2 that were easy to get at. Piece of cake.
--Rob
2002 GMC K2500HD D/A SLE SB EC<br />Banks Stinger TLC System, exhaust brake<br />Lucerix mirrors<br />Deep Allison trans. pan, TransSynd<br />Armaguarded box<br />Hijacker 5th wheel hitch<br />Redline TA 1200 brake controller<br />LT265/75R16 Cooper Discoverer A/T 10-ply tires
Ryeguy,
There really are two filters in there you have to reach way back towards the engine compartment to retrieve the second filter.
I didn't have any problems with the screws either.
2001 Chevy 2500HD 4x4 D/A LS Ext. Cab LB
Found the other filter (forward of the one that falls out). Trez dirty. Glad it's changed now. Thanks!
--Rob
Any of you that has changed the AC filters have the big floor console? And if so, is it in the way?
I have 8600 miles on ole Betsy now, and I figure it is about time to clean or change them.
I read on here a few weeks or months ago about cleaning them. Are any of you doing this instead of forking out the bucks for new filters?
2002 Chevy LS 2500HD Duramax/Allison, crew cab, short bed, Forest Green,4x4, Banks 4\" exhaust, Amsoil through out,Amsoil dual bypass and air filter. Torque Pro 2000 by ATS (propane baby)<br /> <a href=\"http://community.webshots.com/user/hdmax\" target=\"_blank\">Mike`s pictures</a>
Replaced cabin air filters today. Had ordered from dealer who said there were two filters, one being charcoal. When I removed them, they were both identical (non-charcoal) filters with same part number.
As the filters came two in a box, I used both plain filters. Should I have installed one charcoal filter? Has anyone found a charcoal filter in their truck? If so, in which position was it?
01 2500HD LS 4x4 D/A Ext Cab Short Box, Charcoal Gray, Linex, Snow Plow, Denali dash bezel<br />4x4 light that now works!<br />Under seat storage bin (paid $31.75), Bilstein shocks, Timbren front springs
here is a couple of links about cabin filters:
http://forum.62-65-dieselpage.com/ub...c&f=5&t=000571
http://forum.62-65-dieselpage.com/ub...c&f=3&t=003727
http://forum.62-65-dieselpage.com/cg...10&t=002527&p=
you should be able to get enough info from these links.
hope this helps
[img]smile.gif[/img]
2003 SLT Duramax CC/SB Carbon Metalic, Juice\'d, JK Light harness, HD sprayed box liner, J&J Millennium running boards, Fumoto valve, Tekonsha Prodigy brake controller, TFP Stainless door handle inserts, Michelin LT265/75R/16, combination Tool Box & Fuel tank(165L) with timed transfer flow, 2 Micron CAT Primery fuel filter, dndstarr@shaw.ca<p>PIC\"S <a href=\"http://photos.yahoo.com/bc/hx30/lst?.dir=/duramax\" target=\"_blank\">http://photos.yahoo.com/bc/hx30/lst?.dir=/duramax</a>
if you go to this link it give you pictures from Mackin's album...thank him for the pic's:
http://www.picturetrail.com/gallery/...579&uid=412377
Checked out all the links to various posts. None of them mentioned a charcooal filter. Both of my trucks filters were the same. Did anyone find anything different?
