I never got an owners manual with My truck so I have to ask.
How many foot lbs should i torque the lug nuts to. I have the 8 lug wheels.
Thanks,
Thanks,
K2500 4x4 Regular Cab Long Bed 6.5L Turbo Diesel 170K and still strong.
My 1999 Suburban calls for 140 lbs-ft for the lug nuts. Remember to go back and forth around the lugs to evenly torque them. For the 8 bolt - I described the pattern to my kids as the "Two Box offset". With 8 lugs, you can see 2 boxes. Tighten the corners of the first box, then move one(1) lug, the tighten the next box. For a more even application of the torque, come up in steps. This will allow the wheel and hub to remain straighter. But you knew most of this.
HammerWerf
My 1998 calls for 140 1b-ft.
My Dad's 1995 manual calls for 120 1b-ft. Not sure why the difference.
Joe.
2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
1996 Chevy C2500 6.5 auto Ext. Cab LB
Thanks for the Info, I'll use the 120 lb ft.
