the 01 is on the way out and the 05 should be here this week
i remover the brake controller from the 01.
can i just plug it in to the 05 or do i need to rewire it to a new plug.
tia.
jim
tia.
jim
jim
You will have a new plug.
2005 Chevy 2500 HD Duramax CC SB 30,000 miles.
1994 GMC 2500 Suburban 6.5 TD 210,000 miles.
1983 Mercedes 300 D Turbo Diesel 150,000 miles.
1991 Holiday Rambler Aluma Lite XL 30 foot.
i kinda figured that.Originally posted by Dewey Faircloth:
i want to know if it's the same so i don't have to rewire the controller.
jim
My understanding is you will have to rewire it because the pin location in the fuse box is different.
thanks
jim
When i changed from 02 to 03 i took harness and control and transfered to 03. It plugged in OK but big mistake. Pins are different. Check with your hitch people or dealer if you want to lower your pride enough!!!
There is an upfitter bulleting at the GM website that explains what changes to make to your old harness. If you don't make the change, your brakes will apply when you turn on your lights.
DOOH!
I think the new harness is $25
2003 K3500 Crew Cab, Banks Stinger Pkg, Exhaust Brake & Exhaust, OilGuard Bypass filter, Lube Specialist Secondary Fuel Filter, Allison Deep Pan, TTT Mirrors, B&W Turnover Ball and Companion Hitch, Truck Trunk Sliding Box and V-Box, LINE-X, Co-Pilot Live GPS, Hitchhiker 31.5 LKTG 5th Wheel 28' Wells-Cargo Gooseneck Car Hauler
two of the wires are different on the 01 plug
i didn't rewire the controller, i just pulled the pins and swapped the two wires. as i recall they were the light blue and the brown.
on another note my banks exhaust from the 01 bolted right up to the 05 as did my front mounted hidden hitch.
jim
That's all I did going from my '02 to my '05. The '05 came with the proper plug in the glove box. I'm almost sure the '02 did too.Originally posted by justforme:
