Results 21 to 40 of 42
Thread: Can Synthetic ATF be a substitute for GM Automatic Transfer Case Fluid?
  1. #21
    Dec 2002
    Terre Haute IN
    Art,
    As in my case the chain grinded all the way through the case on the top rear near the tail shaft. If you are hearing noise it could definatly be the chain rubbing. At your point it could just be a hair line crack, almost totally unnoticable!
    99 K2500 GMC Ext Cab, 6.5TD, Heath ECM reflash, TDC Offset -1.80, Bumped Optic, FSD Isolator, Turbo Master, KD 3.5" Exhaust, 4.10s and 33x11.50, Intercooler is next.
    98 Burb 350 1/2T/4l60/246/10Bolts - Wifes Ride
    80 Olds Cutlass 6.2/Studded/700R4/12Bolt 3.30s/IP=4544 Juiced by JK/Best MPG=30
    79 Olds Cutlass, 410ci/700R4 - Currently Restoring
    1992 Mitsubishi Eclipse Turbo, currently 12PSI max boost
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Email= Dr.Diesel@gmail.com WA9SDJ
  2. #22
    Nov 2003
    Edison, NJ
    Quote Originally Posted by AndyL
    Art,
    Guess the bulletin board never sent me the notification email as I'm just seeing this now. I only get noise when the fluid is really low. It has not made noise in a week since I replaced the seal and added fluid. I need to look closer but it doesn't seem to be leaking anymore. Not sure exactly what that means. I'll let it go another week and then check the fluid level.
    Thanks,
    Art.
    Art Paltz
  3. #23
    Nov 2003
    Edison, NJ
    Well after being completely frustrated with this damn leak I took drastic measures. I have tried replacing the tail seal on the transfer case and that didn
    Art Paltz
  4. #24
    Apr 2004
    Palm Beach, Florida
    Default Case leak
    Art, sorry to hear your still having trouble w/t-case. The rear case half can be bought along with chain, clutches, steels, etc., bit less than a rebuilt if you have the time and knowhow.
    When I changed out my NP246 it was because of the tow shop towing it in gear which resulted in damaged t-case.
    New NP 246 can be had for just under $1,000. consider this is about 1/3rd of what dealer charges.
  5. #25
    Dec 2002
    Terre Haute IN
    Art, you would have to change the output shaft on the tranny as well, which requires a complete tear down! And then a new driveshaft!
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
  6. #26
    Nov 2003
    Edison, NJ
    I was really being tongue and cheek about converting it to 2WD.
    I've rebuilt more transmissions in my racecar than I care to talk about. Maybe I'll get through this season with just one.... The actual rebuilding or installation of a new transfer case doesn't worry me too much. It
    Art Paltz
  7. #27
    Jan 2002
    West Orange, NJ, USA
    Post Amsoil says that, too
    IMHO most cases it would be fine, expecially if you used a high quality fluid like Royal Purple. The one exception could be your Burb, GM went through several revisions of fluids attempting to cure the NP246 wear issues. The NP246 in the wife's Burb chucked the chain gears through the side of the case while driving home from Tampa Florida! And that was at 90K miles.
    I was looking on Amsoil's web site for Synthetic ATF for my 99 Tahoe 4wd (5.7gas) and it said their Syn ATFs were for OTHER THAN AUTOTRAC transfer cases, to use the GM fluid for that one. Guess Amsoil doesn't want to get in the middle of GM's problems for the 99s (other years, too?)?
    Have to keep a close eye on that transfer case I guess.
    Dave in NJ
  8. #28
    Nov 2003
    Edison, NJ
    Quote Originally Posted by curmudge1
    Dave in NJ
    I believe both Red Line and Royal Purple list their fluid being a replacement for the auto track fluid.
    Where in NJ are you? I'm in Edison.
    Art.
    Art Paltz
  9. #29
  10. #30
    Apr 2004
    Palm Beach, Florida
    Default NP 246 lube/fluid
    The guys that sell the NP246 new & rebuilt call for synthetic fluid to be used.
    Doubtful GM's blue stuff is any better, but it sure cost's like it is. I'm running B&M's best synthetic so far no issues.
    Remember this t-case has 9 clutches and 10 steels which help absorb the shock when front and rear shafts are at different speeds in auto 4wd.
  11. #31
    Nov 2003
    Edison, NJ
    Quote Originally Posted by DA BIG ONE
    Something that sort of puzzles me but I think I'll be able to answer it myself is this. I always assumed the transfer case used clutches to engage 4WD as well as "LO" gearing. If it's using clutches, why is there a chain? Is the chain what transfers power from the main shaft that I assume drives the rear wheel to the front drive shaft? I would have thought it would have been a locking gear that did this but I know there is a chain in there somewhere.
    Additionally, are clutches used in auto 4WD to stop and start power delivery to the front differential or is the locking and un-locking done in the front differential? My assumption is that it
    Art Paltz
  12. #32
    Apr 2004
    Palm Beach, Florida
    Default Clutch?
    Quote Originally Posted by TurboDiverArt
    Additionally, are clutches used in auto 4WD to stop and start power delivery to the front differential or is the locking and un-locking done in the front differential? My assumption is that it’s in the transfer case. The front hub probably disconnects in 2WD but is locked in 4WD and Auto 4WD. Hence the reason you get worse mileage in Auto 4WD even though it’s not engaging on dry pavement.
    Art.
    The clutch is always engaged, the encoder motor adjusts the amount of clutch pressure using input from the ems, abs, along w/frt/rear drive shaft speeds in Auto 4wd only, otherwise the clutch is fully engaged unless in neutral. W/o clutch pack and pressure control of encoder motor in auto 4wd there would be shock waves from engaging/dis-engaging affecting drivetrain to the point of something breaking.
    With autotrac front driveshaft rotates always "but does not drive the frt/diff inless in a 4wd range", when shifted into any 4wd range the front differential engages locking the frt/differential to driveshaft power through t-case would be direct in in 4wd hi/lo but controlled in auto 4wd. The front diff carrier is of the open design.
  13. #33
    Nov 2003
    Edison, NJ
    Ahhh, that makes sense now, thanks!!
    Art Paltz
  14. #34
    Nov 2003
    Edison, NJ
    Default I found the leak!
    Well, I found where the leak is coming from. I have found a small hole in the rear tail shaft housing. It doesn
    Art Paltz
  15. #35
    Apr 2004
    Palm Beach, Florida
    Default Hole
    Only speedo pickup behind there, maybe just a casting flaw. The clutch/plate assembly is on the other side forward of the chain.
    Thinking you maybe ok w/your fix!
    PM me your e-mail I'll send a drawing of the t-case internals.
  16. #36
    Nov 2003
    Edison, NJ
    Just PM'd you.
    Art Paltz
  17. #37
    Apr 2004
    Palm Beach, Florida
    Default Glad to have helped ya!
    Just PM'd you.
    When I paid to have repairs done I could have cared less that I knew little, or nothing. Since getting burned more than a few times by so-called certified repair shops I've been in a learning curve w/this burb and have collected lots of info not available in repair manuals.
    The diesel page has helped big time.....
    Again, good luck.
  18. #38
    Nov 2003
    Edison, NJ
    Well it's been a couple of days and no leaks, at least 100 miles. I cleaned the hole and scuffed the area real well. I put JB weld on the area and covered it pretty good. Actually three coats. The first one I put on when the transfer case was warm. That was a mistake as the JB weld became liquidy. It did get in the hole real well. I subsequently coated the area two more times. So far so good. Going on vacation next week so I'll be putting on an additional 500 miles so that will be a good test. Thanks for all the help, TDP is great.
    Art.
    Art Paltz
  19. #39
    Aug 2003
    Bakersfield, Ca
    Art,
    Been a year and a half since your repair. Still holding? I hope so. as I may be looking for a similar leak.
    HammerWerf
  20. #40
    Apr 2004
    Palm Beach, Florida
    Thumbs up Suspect his case had casting flaw
    The NP 246 AutoTrac is a good stout unit not suffering the issues of wear through other t-cases have had.
    However, when my NP 246 had to be replaced it was because of a tow truck operator who swore he knew what he was doing, "he didn't", when he had to pay for the t-case replacement then he really knew! Towed the truck w/o placing the t-case in neutral which quickly damaged unit. Factory NP engineers were the ones to report to me that a good synthetic fluid is good to use in the NP-246, so far, so good.
    I'd like to get a report too.
