Thread: no tach, check engine lite, black smoke...
    Oct 2004
    Webbwood, Ontario
    Thumbs up no tach, check engine lite, black smoke...
    Hey group. I just picked up a 95 6.5 Turbo.....driving it home, there's no tach, check engine lite is on, lots of smoke, hard on fuel.....what to look for ?
    Any info will help.
    Kev
    Daily ride: 1986 C10 6.2 with 700R4, Banks Stinger kit, diesel pro dual idler, J code intake, Wrangler package.
    New project: 1995 2500 Ext cab 4x4, 6.5TD, AOD, cheap, but really rusty....we'll see how it goes !!!
    Nov 2003
    Sun City AZ
    Default NAHhhh...
    Wouldn't be something as simple as a missing, or slipping fan belt? ( drives the alternator and the vacuum pump for the turbo) Did it overheat?
    OOps sold my "baby" - 96 K-2500 6.5TD - ~047,068mi, Isspro's Boost, Pyro, and Tranny temp; Heath Plate Remote mounted FSD; Amsoil Fluids and Air; Bilsteins, BD Down Pipe-Gutted CAT-& B-D'ized 3.5 Kennedy exhaust; '97 cooling upgrade; CAD upgrade; new IP at 34,700 under warranty; Homemade: Boost fooler, Hi/Lo idle, OPS relay, TCC Lockup ( TFT), Glow extender for AC60's, & "GMC H..'s" 6 position Shift modifier .
    Apr 2002
    PA
    Default Could be 2 seperate issues or more...
    Kev,
    Lots of smoke and poor fuel mileage indicates a lack of turbo boost. I had the same problem with my recently acquired '95 Tahoe 6.5L TD. I also had a "check engine" light, a code 35 which has to do with the EGR system. I solved my issues by installing a TurboMaster to replace the factory boost control system, and replaced the factory 'S' computer chip with an 'F', which doesn't look for EGR equipment. While removing the factory boost control stuff, I discovered the wastegate diaphragm was bad. For the factory setup, you want to inspect the vacuum pump, vacuum hoses, wastegate solenoid, diaphragm... I prefer a little simplicity. Just filled my truck up since the TurboMaster was installed, and I gained 2 mpg in city driving.
    I also had a problem with the speedometer becoming erratic, shooting 30 mph faster than actual speed, then dropping 10 mph below before finally settling back where it should be. My tach would also either freeze at a particular RPM or it would just quit like you turned the truck off. The trans would get stuck in limp mode (2nd gear). The gear select light in the dash (which tells you what gear the trans is in) would go out. Replacing the ignition switch took care of that.
    1994 K1500 Blazer: 6.5L TD/4L80E: 'F' intake: Kennedy chip: Kennedy 3.5" exhaust: Heath Turbo-Master: 2/0 battery cables: Lubrication Specialist oil cooler lines: Fumoto drain valve: Amsoil dual bypass remote oil filter kit: Fluidampr: 137k miles
