I have an 88 C1500 that started to give a rythmic squeak at low speeds (idling to about 30). It sounded very similar to the sound that worn brakes make but it will only make this noise when there is torque applied, if I let off the gas pedal the squeaking usually stops. Soon thereafter, I started to hear a very pronounced driveline clunk when I would put it in gear or when I would let off the pedal at high speeds. I crawled underneath to check my u-joints and found them to be ok, however my output shaft from the transmission has alot of play in it.
Is there some kind of carrier bearing in the tailshaft that I could replace or does this sound like something else? How tough would the repair be?
-AFK
