Stall Speed ?
Automatic requires the lowest stall speed you can get, if you have deep pockets a custom unit can get your stall speed down even more.
However, the tq of a diesel engine is much more than most gassers at low rpm's; so let's talk tq multiplication of a converter if the tq is increased x 2 and your motor is putting down say 300 ft lbs tq @ say 1,000 rpms then you get 600 lbs tq just as wheels start to spin then it goes back to the 300 mark after you are moving.
