Originally Posted by
Steve_M
Anyway, please clarify PMD vs FSD? My Trouble Shooting book says "Pump Mounted Driver (Fuel Solenoid Driver)". So am I safe to conclude that they are one in the same?
Yes, the same.
Sounds like you are on the right track.
The connector can be removed by using a long, thin screw driver to release the clip-lock on the side of the connector and levering the plug off the PMD. Be aware, the chances of getting it back on again successfully are somewhere between slim and none!
Good luck with the warranty. My guess is you are at or over the 11 year limit, but, the dealer has some lattitude to press for warranty coverage. If you have a relationship wit a dealer, that's the one you want to go to.
Sometimes the dealer wants to see stored fault codes, so, whatever you do, don't pull the fuel solenoid fuse and crank the engine, as it will set codes....
