Results 1 to 7 of 7
Thread: 1998 K3500 overhaul - day 3
    Jan 2007
    Victoria, BC, Canada
    Default 1998 K3500 overhaul - day 3
    Since our last installment a few things have gotten done. I
    1998 Chevy silverado 3500 4x4, 6.5TD, 215000 miles, 4L80-E, 4.10 ratio, 6" lift, gauges and intercooler... and a newly rebuilt engine on new block and heads!
    Knoxville,Tennessee
    Wink
    Take look at the pitman arm and the idler link too. Week links in these trucks.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Jan 2007
    I've got the chilton guide and the alldatadiy version of the service manual, but neither one gives instructions on evaluating the pitman or idler arms, only replacement instructions. If it feels solid is it good?
    more special tool questions.. steering linkage puller j-24319-01 and installer j-29193 - needed? aftermarket alternatives?
    thanks!
    Knoxville,Tennessee
    Talking
    Quote Originally Posted by derekja
    thanks!
    Feel for slop at the end connecting to the tie rod. You will need to remove the steering box to get the arm off and a standard gear puller works fine. Pitman arm is mounted to frame, just unbolt it and seperate from tie rod, pickle fork works fine. Remember to lube pitman arm. Gets missed because you have to drop fron skid plate on 4x4s.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    A little foggy-eyed this morning, 5150?
    The pitman arm is attached to the steering box output shaft, and the idler arm is attached to the frame. They do get neglected, and I think that's the reason they get on the common failure list. The scream for grease, but don't get enough.
    I know it seems like the money is just continuing to add up, but I'd replace the steering components while you are in there. If everything else was neglected and in bad shape, those are probably in a similar state. Better to do it now than have it all buttoned up and then find you have to tear it down again a month after that job starts and you need to drive the truck to work...
    Diesel Page Member #2423
    Jan 2007
    ordering question... It's pretty tight in there get at these pieces. Next week I've got to move the truck back a few feet so that I have room to pull the engine out, so I'm putting the front end back together.
    I've about got myself convinced that it would be better to get at the pitman arm and idler arm when the engine and radiator and all are out of there to make more room. It doesn't look like anything but the inboard end of the tie rods would need to be touched again if I did things in that order.
    Is that reasonable or am I missing some reason that it would be better to do this with the rest of the front end right now?
