My Suburban has the "tail gate" or horizontal rear doors.
Does anyone make an external rear spare tire carrier, that mounts to the back and can swing out of the way to access the tailgate?
96 Suburban K2500 6.5L TD. High miles and daily driven (for now). Remote mount FSD with cooler, Turbo Master/Boost fooler, 4" Jardine turbo back exhaust, 2.5" cross-over pipe, Boost, EGT, & Tranny temp gauges, working on more.
I have a '91 Toyota 4-Runner with the swing out tire carrier, you may want see if that would be able to adapt and can fined one at wrecker or such. I would guess the option one for a Tahoe or Yukon would work too. I think you could purchase aftermarket.
'95 GMC K2500, "Bullet"Ex. cab short.4X4, 377,000kl on truck, 177,000kl on AMG engine, auto. 3:73 Ltd. slip, FSD remote mount, OPS relay,AFE air IN, Kennedy 3 1/2" OUT . '83 F250 HD3/4 " Robert The Red Ford"4x4 460, 3:55'posi . 2005 GMC : G WHIZ" crew short box, 5.3, 4:10. , '88 Bronco II 4X4, '95 141,000kl Ford F150 EX. short box, '92 "Toy" 4 runner 273000kl ,'63 Mercury 45000miles !!!! Auto insurance co. is my mistress !!!
Yeh, I've thought of checking the junkyards.
I just wanted to see if they made one for the Suburbans.
For your suburban, I've seen those safari roofracks with spare tire mounts, but getting it up/down would be a PITA.
I have a reese-style hitch mount on the front of my truck, and a spare tire rack is available for that as well.
Check out www.tiregate.com nice stuff, for pickups only, but worth mentioning.
good luck.
1994 GMC K2500 L65 4L80E with 230,000miles 16mpg, Kennedy Chip, FSD Cooler, Straight Piped, RoyalPurple/Longrider 40W15 oil, PowerService DieselKleen, H2 rims with 265R17's and GMC centercaps.
2005 VW Golf TDI, 72,000miles, 41mpg, all stock so far, B20 (Spinx fuel stations)
Try,
http://www.kenmtn.com/
Good quality......
I have considered the roof top carrier, but you're right, getting it down wouldn't be too joyful (especially for my wife)! And, I'm not too sure about adding that much height to my rig. Some of the garages I park in don't have too much clearence.
If my Burb had the "barn-doors" I'd just bolt a mount to one of the doors, but I don't think that would work too well with the tail gate (adding 60lbs).
Cool stuff! Thanks for the links guys.
The H1 has a carrier that cranks up and down from corner of frame or a bumper. It has a rachet turnbuckle so tire can be rolled up to carrier lined up to lug studs bolted up lifted up to storage mode.
Hmmmm.... I can't picture it.Originally Posted by DA BIG ONE
I'd like to get some more cargo space in the back of my Burb, but it might not be worth it.
That Kennesaw Mountain Multi-Carrier sure is nice, but pricey!
