Need Dual Shocks, so
I've been mulling around dual shocks for some time now, bought aftermarket hoop setup but will not work on my burb w/o lift.
So, considering modifying the stock mounts to mount 2 stock shocks each back is not a big deal, but up front I'd have to move the upper mounting point out from chassis to say 2+"'s and wondering if the change of angle of upper mount would defeat what I'm trying to do, or?
