Results 1 to 8 of 8
Thread: Rear brakes
    Knoxville,Tennessee
    Question Rear brakes
    On a 94 k2500, where is the difference between 13x2 1/2 and 13x3 1/2? Is it just in the drum or is the backing plate different too? I've looked at Napa online but they only offer 15x5 at $549. Don't think I can sqeeze those between the wheels...........
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Jul 2005
    IL
    Cool brake question
    If memory serves me right the 2 1/2" are the brakes on a light duty k2500 and K1500, with semi floating axles. ( the ones where you have to remove the internal clips to remove axle)
    3 1/2" are for HD full floating axles( one where you remove the 6 outter axle flange bolt and axle comes out) K2500HD and K3500 SRW or DRW trucks
    why do you want bigger brakes?
    hope this helps
    2003 CHEVY 4500 DURAMAX/ALLISON 14'
    SERVICE CRANE BODY 16,500 LBS 14.5 MPG
    1998 K3500 SRW CREW CAB TRANSPLANTED 6.5TD ELECTROINC INTO, HEATH COMPUTER, 40+HP INJECTORS, 4" EXHAUST, VACUUM ELEMTINATOR ON TURBO,UPGRADED COOLING WITH ALL GM PARTS,NO VACUUM PUMP, SST OIL COOLER LINES MADE LOCALY FRACTION OF THE COST, 3" TOURBO/BOOST GAUSGE ALL IN ONE, ADDED GEAR DRIVE GREAT HELP WITH STARTING TIME DOESN'T JUMP AROUND ANY MORE, INTERCOOLER 3" INLET AND OUTLET COOLER 12x24x4, ALSO ADDED MANDEL BENT CROSS OVER, HAD TRUCK REPAINTED AND OPUT ON ALUM FLAT BED
    Knoxville,Tennessee
    Wink
    Quote Originally Posted by redbird2
    hope this helps
    Because it came that way stock. Got rear ended by a 76 Buick wagon a few years back and the Stealer that did the work replaced the rear axel with one from a 92 and it has 2 1/2 in brakes. Had a car stop short on a yellow last nite and realised just how poor they are. That and I have a 36 ft fith wheel. I would like to go disc but that is a whole nudder story.
    If it's drum and shoes that are different that is the easy fix. If it calls for backing plates too, I might wait a little longer and just through a late model rear under it and get the disc brakes that way.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    Aug 2006
    Fresno, CA
    When you start talking about that 5-600 range, disc is right around the corner. I've had it on 4 trucks now, and won't ever touch a drum, except to take them off!
    The only minor issue... I don't like like-locs, and have not found parking calipers that I've fallen in love with yet.
    Jun 2006
    St. Albans, WV
    So, Rover, you have switched over to discs?
    I'd like to hear about the conversion.
    96 Suburban K2500 6.5L TD. High miles and daily driven (for now). Remote mount FSD with cooler, Turbo Master/Boost fooler, 4" Jardine turbo back exhaust, 2.5" cross-over pipe, Boost, EGT, & Tranny temp gauges, working on more.
    Aug 2006
    Fresno, CA
    I've switched to disc rears on every chevy I've ever owned. So far, I've only done 1/2 tons, but have helped with several 14 bolt rear end conversions, and a few Jeeps too.
    I'll take time to snap a few pictures when I'm at my shop on wednesday, and write up a little narrative then. there are a lot of ways to do this, but none require any special skills, and most are easy.
    The biggest problem I've had with disc rears is that you can get sideways really quickly if you do not replace the stock proportioning valve with an aftermarket one.
    -Nate
    Knoxville,Tennessee
    Question
    Quote Originally Posted by RoverIIa
    How bout driveline disk and caliper?
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    Jun 2006
    St. Albans, WV
    Cool, thanks. I like to see the pics and read your narrative.
    I have the 14 bolt full floater and I have been contimplating the swap for some time.
