Is this common? Alot of front diffs I see listed on www.car-parts.com say they're cracked...
Side note - if anyone has one they want to sell me for cheap, that'd be great (3.42 ratio btw)
Eric
'95 Tahoe 6.5TD
Current:
3" Turbo back - 14 bolt SF - Vin F intake manifold - typical guage pod setup - Turbomaster - Free blowby mod courtesy of GM's 22:1 + boost
Coming:
Cummins IC - new turbo elbow w/ 3.5" DP - 4" Intake - new block w/ 18:1 slugs
I don't hear of many cracked front axle housings. Off the top of my head, I don't remember discussing any in the emails I've seen - in 11 years....
The 1/2-ton front axle housing and R&P in Lil Red have held up to 4WD launches at the track - in a truck that dyno'ed at more than 500 rw horsepower and 1000 lb-ft of torque. This included runs up to ~120 mph in 4WD. I did twist off a stub gear in the front axle disconnect assy once cuz the 4WD didn't engage till after the rear wheels broke loose.... Not the axle's fault that time...
Now, the NP-208 transfer case is another story. I had one crack in the 1982 GMC I once owned, and I've heard of others.
Used front axles assy's are available at auto salvage centers for about $400. Last time I checked, anyway.
If you are refering to the 95 its very possible since the housing is all aluminum.
If the mounts get worn a tad they can allow things to tweek and then they break.
Any front collision that sends shock from wheel to diff will damage case IMHO.
