Hey Shed,
Here is the software history for the vehicle. Now what I can't tell you is how current your software is. This just shows the software progression for the supplied VIN. The most recent calibration will be at the top of each section. You will have to have the dealership hook up the Tech 2 and go through the steps to find out how current your software is.
VIN: 1GCHK29121E289570
Controller: PCM/VCM Powertrain/Vehicle Control Module
Calibration History for: Operating system
Part Number CVN Bulletin # Description
15188873 N/A - New software to correct false setting of DTCS P0116 and P0181.
15097100 N/A - New software to improve generic scan tool operation
15063376 N/A - New calibration to address driveability and emissions compliance issues
9393838 N/A - Operating system
Calibration History for: Engine
15097103 0000812F 210730034 New calibration to address excessive shifting with cruise on and idle surge
15082517 00006CCF - New calibration to reduce roughness on hard acceleration above 2600 RPM
15076142 000052D3 - Calibration to correct false trouble codes and a misfire condition. Also addresses P0234 diagnostic codes.
15072655 000023B8 - New calibration to address driveability concerns while in tow/haul mode
15063385 00009119 - New calibration to address driveability and emissions compliance issues
9375153 00008FBC - Engine calibration
Calibration History for: Engine diagnostic
15097105 0000A513 - New calibration to correct setting of false DTC P0236
15082519 00008FCC - New calibration to address the throttle pedal progression issue at 0 percent
15076144 0000A75E - Calibration to correct false trouble codes and a misfire condition. Also addresses P0234 diagnostic codes.
15063387 00008DF1 - New calibration to address driveability and emissions compliance issues
9375180 0000C6D9 - Engine diagnostic calibration
Calibration History for: Fuel system
15189542 00006BD9 - New calibration to correct false setting of DTCS P0116 AND P0181
15063379 00004F59 - New calibration to address driveability and emissions compliance issues
9375210 00003FE0 - Fuel system calibration
Calibration History for: System
15097111 00001429 - New calibration for improved power in reverse when in 4WD low
15082525 000010CA - New calibration to revise the oil life calibration from 5000 to 7500
15063393 000087CB - New calibration to address driveability and emissions compliance issues
9375220 000073F3 - System calibration
Calibration History for: Speedometer
15063401 000053E8 - New calibration to address driveability and emissions compliance issues
9375243 00009B57 - Speedometer calibration
Print Close
