700R4 or 4L60E
I am considering a swap with a 6.2 diesel. I have both a 700R4 (about 1983 from a diesel, also have a 1989 from a V6) and a 4L60E (1996 from a 4.3 V6). It will be 4 wheel drive. Which trans would you use, what are the pros and cons of each? and will the 4L60E internals fit in the 700R4 case, to fit the transfer case, or will I have to get the 6 bolt adapter?. I would like to use the best of what I have. Looking for daily milage and maybe light occasional towing of a ski boat, but that is what the K3500 is for.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
