Alternate fuel
My apologies for the late reply…..To summarize my alternate fuel endeavors since last post. At about 7000 miles using the diesel secrete mix, I got a bad batch of oil and clogged my injectors. I was blowing so much smoke back home, I looked like a coal fired smoke stack. I finally attributed this to either hydronated oil or too much grill cleaner in the oil I picked up. A buddy I have been sharing oil with noticed the same rough running problem with the same batch. His wasn’t as concentrated as the oil I had in mine though.
About two weeks after I replaced the injectors , my pump went. BY this time I was getting discouraged. I replaced that next and went back to running diesel until I could figure out what was going wrong.
My alternate fuel buddy had since figured out that we had not been letting the oil sit long enough to settle the suspended water out of it.
I now have about 3000 miles on filtered oil that is free of water and noticeably better running. I have been cutting this oil with about 40% diesel. No problems as of yet. -----Let your vegetable oil sit 3-6 days before filtering. Take it off the top and pitch the bottom sludge. Filters last longer too.
Not using the diesel secret these last 3000 miles , just filtered oil and diesel.
94 Burb, 300k, 3/4, 6.5TD, remote FSD, 130 w/dual crossover, gages, turbomaster, 3.73, wvo not filtered good lead to new injectors and ip --working on making bio now-- 95Burb, 156k, 3/4, 6.5TD, remote FSD, Banks exhaust w gages, 130 w/dual crossover, 4.10
