Well the need to do some HVAC work on the dually has prompted me to write a little ditty.
The AC system on our trucks is very simple for the most part and servicing it need not be a mystery.
I have done a buttload of AC stuff over the years and have owned most of the equipment to do such.
With the onset of the 134A juice in the mid 90's many of the tools changed.
The service ports changed to a larger quick connect type as well as many of the internal seaqls and such in the pumps.
Also the sniffers used to detect leaks have changed. Mine was an R12 unit and will not do any other materials.
Off to the NAPA store to get a new one. Now the sky is the limit as to what you can spend for a tester but the little cheap one at $179 will do the job but you need to get creative to avoid false alarms.
My system had a GROSS leak that had popped up over a day or two.
actually I think it was there all along and just took the stress of real hot weather and the higher highside pressure to reopen the wound. (crimp on the highside hose.)
You cant really find leaks without tools unless they are so obvious such as a hiss or a lot of oil seeping from a crimp area or a condenser core.
My first concern was of course OMG I hope its not the evaporator in the cab.
This is some serious work to get out of the truck.
I get the new sniffer and read the instructions (YESSSSS this is a good idea) as the folks who built it probably know more thanI do about it.
I first go to the cab and run the little devil around under the heater box and it instantly goes berzerk. Expletives deleted!!!
After stomping around and uttering things very unlady like I read the book more and it says " areas with moisture may cause a false alarm"
I head over to the Burb that has just come in from town and stuff the unit under the heater and it goes Berzerk again.
Ok, after a sigh of relief I head out front and start probing around the hoses and fittings and soon discover the real issue at hand.
The little sniffer is cherping away quite adamantly when it gets close to the highside hose crimp as it passes through the header on its way to the condenser.
Game over, evacuate the system into the holding tank and remove the hose assembly. This morning its off to the warehouse to get a new set.
Just one of those little things that can bite you in the butt.
The moral is, the better quality tools will give better results with less chance of errors but if one is careful you can do fine with the entry level stuff.
Years ago when dad and I had the shop, as dad used to say, the best is none too good.
For the home shop the entry level tools will get the job done fine.
One thing though when working on HVAC stuff. Be careful and use all the proper protection gear and be safe. While not dangerous, improper procedure can get you hurt.
Refrigerant is nasty stuff if it gets sprayed in your face or on any exposed flesh. (Super cold can cause frost bite and severely injure eyes) or worse
Dont breath the stuff either. If you have a leak in the rig, ventilate well and evacuate the system before working inside.
Just some observations that come to mind
