DMax, as far as the BBB goes, "pissing in the wind" BBB is mostly BS. Why would a simple service cause the air leak?? where is there a connection other than coincidental?? I would not rebate $100 nor worry about the dealer bill!! if I know I did not cause the problem. Did I miss something??
As for the ATF in the filter, not the best idea for late model engines but should not be a problem. I would not want an IRS fuel sample taken, may be just enough pink to pull down a hefty fine. bob...............
Bob O.
