Results 1 to 7 of 7
Thread: Rear air in Suburban not cold
    May 2007
    Middle GA
    Default Rear air in Suburban not cold
    The rear air in my Suburban is not blowing cold at all. The air comes out like it should but feels the same as ambient air. The front air blows cold when I am moving but when I sit still for more than one or two minutes it slowly starts to get warmer and approach ambient. Where should I look first?
    Thanks!
    Default moving air
    Front and rear air are really just 2 ends of one hose, so to speak.
    your marginal performance up front will magnify losses to the rear. R134 systems really have to be "up" to work well. R12 could tranfer heat faster so a marginal charge would still cool. It is also possible for a R134 system to be ok and not work in the driveway, you need air moving over the condenser out front to get the thermodynamic cycle working. Check the condenser for any folding of fins and make sure the space between the radiator and condenser is clean.
    Sidehackbob
    78 93" flh
    98 80" flt
    93 K2500 6.5 TD auto K&N, straight pipe, 276K
    78 K25 292+.080 ported headers 4bbl mucho rusto
    79 F150 2wd 460 balanced ported, performer, 780 Vac, headers, duals, jacobs, mucho rusto 225K
    You really need to stick a set of gauges on the system and see what the pressures are.
    High side needs to be up about 175 or so and the low side should be down in the mid 30's when the system is running.
    The high side will run higher when the weather is warm too.
    when the system is working right it should cycle the clutch every so often as the system draws down into very low pressure.
    The front is an orifice tube and the rear is controlled by an expansion valve.
    Try using some 134 cans and add some refrigerant with the system running. (Add to the low side fitting)
    Once you get good cold air you are probably close enough.
    Look the system over and see if there are any visible oil stains on the fittings indicating a leak.
    If you find a leaky area fix the leak then recharge the system.
    May 2007
    Middle GA
    I'll go put some gauges on it tomorrow. Do I need to let it run for a few minutes before checking the pressures?
    My suburban is a 1995, is it r134? I think I saw a sticker under the hood that said it was but I am not positive.
    Yes R134A
    Let it run for a couple minutes to get the pressures stable.
    Mar 2007
    odd factoid: my rear ac blew ultra cold and my front ac was just above ambient. Added some 134 and it improved the front quite a bit, but rear is still ten degrees colder
    www.youtube.com/dieselsailor
    94 Sub 2500 4X4, 130k 3.73,19.5mpg hwy 12.5mpg tow,oil/diesel leaks fixed,(3-07),ES9000 Pro Comp Shocks!(4-07),amplifier on order!(4-07),New Lift Pump!(5-07),Ram-air/cold air intake!(5-07),Optima Red tops! (5-07),0 gauge battery/alternator custom lines! (6-07),New condenser & harmonic balancer (7/07),New rims and tires-265/75/r16! (7/07),Sound system done! (8/07),Alternator blown from sound system (8/07),160 amp alternator on order!
    Planning: cooling upgrade, 4" exhaust, injectors, tow chip, triple gauge pillar, and gps in-dash.
    Mar 2007
    the above problem was due to a weak compressor. Problem solved, I'm hanging meat right now.
